Handling 28(39) boat-gctid819955
    Well, my nephew has his late fathers 28' boat but he hasn't taken it out on the water yet. It is licensed and insured, both engines running good. He asked me if I would captain it next week so we can give it a sea trial. I am cool with that but it is a larger boat than I am used to. My question is about what to expect as regards slow speed handling around the dock. Backing it out of the slip and turning it using the engines at low speed of course. It doesn't have bow thrusters or anything like that. I know enough to use one in reverse with the other forward to position it as I want it, just not sure what to expect from it. It is a 77 Carver 28' with twin Ford 302 inboards.
    1988 Capri Cuddy 1950 OMC 5.7
    If you're not skilled at maneuvering twins with forward and reverse on the drives, best to get it in open water to practice using the steering wheel and the skills you have now. If you do use "the sticks," don't use the wheel or the throttles. And as always, never go faster than you're willing to hit the dock!B)
    Jeff & Tara (And Hobie too)
    Lake Havasu City, AZ
    And 13 others...
      +1 and I'd add: have extra hands on deck at the ready to "fend off" in the event the wind, current, or other possible unknown sends you in an alternate direction, as into another vessel.
        Are there any of those "I'll teach you hour to operate your boat." Schools around? It would probably be money well spend. He should also take along whomever is generally going to use the boat with him. Kids under ten maybe not so much. Unless there's a large physical issue, like he's in a wheelchair, with practice he should be able to single hand a good deal of the time.
          My issue is that I am just uncertain how the boat will handle at low speed, in reverse. I know the rudders are of no use and it is natural to try to turn the wheel to steer. Using the sticks is the only way to control it. I think my question is, is it best to use both screws when backing out of the slip or will just one screw be best to keep the boat moving slowly? Will single screw cause it to yaw a little? Will two screws be too much reverse speed? I suppose it won't really make much difference and I am probably asking about something that isn't that big of an issue. I plan on getting out into open water and testing how it handles with the sticks for docking when we go back.
            The inboards are fairly predictable in reverse. Your first time out,just bump the boat in reverse, one engine only and watchwhich way the hull walks. If the stern moves away from the dock, give it a little longer bump. Correct the boat to dock as needed by giving the other engine a bump, but just a bump. It takes a while for the the prop action to fully complete work on the hull. Go over to an empty dock you can line with fenders and practice. The fancy looking high powered spinning is, for me, usually when I've gotten myself into a place I'm not comfortable with. I try my best to use a bump at idle method of docking or undocking.
              Thanks Pcpete, that's the kind of info I am looking for. I will try to remember to do it that way.
                I might also chime in here to remind you that the props turn in opposite direction. So the handling in reverse will be different, depending on which engine you play with.
                You might experiment with the dock approach as I have seen many skippers do. Slowly head towards the dock at an angle, put both engines in neutral, then back down to stop your forward momentum with just one engine. The boat will walk one way or the other depending on the thrust of rotation of the propeller. Once you know which engine causes it to walk towards the dock you can then get a little action from the wheel. The water being pushed forward by the prop will flow past the rudder and help the boat move a bit. The question is which way to throw the wheel. A couple experiments in this area and you will nuzzle the boat to the dock like a pro.
                Happy boating
                  Yes..... listen to Jeff in post #2.
                  Get the boat out of the marina and into the water.
                  Once out there, you can practice maneuvering (as though you are in the marina) with the twin engine aspect of control.
                  You'll quickly learn that by using FWD/REV you will be able to turn on a dime.
                  The wind will most likely be your worst enemy at/near the dock.
                    Thanks for all the good comments. My nephew and his wife will be here this evening, spending the night with us and we plan on taking the boat out tomorrow morning. I feel much better prepared after reading all your suggestions, if I can just remember them when I need the help.
                      Docking 101
                      1. (Already stated) Never go into a dock any faster than you are willing to hit it.
                      2. Always turn the wheel in the direction you want the boat to go before you put it in gear.
                      3. Until you understand your boat, put lots of lines out on all sides; better to have them out and not need them, than to need them and they are unavailable.
                      4. Dock cleats are stronger than someone's arms or their legs. Tell your line handlers to slip the mooring lines under a dock cleat to stop the boat.
                      5. Call for assistance, be it the harbormaster or someone ...anyone ....walking along the dock. Most people are happy to assist.
                      MMSI: 367637220
                      HAM: KE7TTR
                      TDI tech diver
                      Kevin
                        Great idea, and great phrase Jeff!
                        Brett & Elise, Sammy + Wilson
                        New Addition - 2002 Trophy 2002WA FF Optimax 135
                        GO HAWKS!
                          Wish I could take credit, but I heard it here first, thanks to Sea Puppy, May he RIP...
                          And 13 others...
