Im sure this might be a loaded question but here we go. I need to do a wot test and het my prop size. But i have a alum prop at the moment. I cant give the boat full throttle cuz the prop seems like its spun at full throttle. But ease into it does good at3200 rpm at 25ish mph . But no more than that cuz it doesn't do much. You can here change in the out drive like cavitation sound maybe but no bubbles? Anyway youll all need wot test and pitch size to figure that problem out. But in real courios a 2 or 3 blade pro set up. Isthere a benefit to going to one of them? I keep reading about the dumbo single blade 16x16 if i remember correctly whats bben your luck with that? I really use my 2655 as a sport towing machine. I just want some good info on prop size for this boat to be used as a tow/speed boat getting on plane quickly with a good top speed too.
2655 prop-gctid819228
