My boat has a B3, I haven't used the boat in about a month and it's on a lift above the water. I just went out to look at it this evening and noticed the drive oil was waaaay low at the reservoir...Well below operating level.
If there were oil in the bilge I wouldn't be able to see it anyway, b/c the lift has a slight tilt to the back.
Can the drive leak while not even in use? Is this a pull the drive type situation?
