Wondered why there was so much water in the bilge once home docked after taking possession 1998 BL Ciera 2655 with Mercruiser 5.7L and Alpha I Gen II sterndrive. Discovered today that when engine is running, water is running out of the bottom edge of where the rubber connector/hose meets the stern exhaust Y-Pipe. Happening on both sides. Picture (port side hose) shows the water "spurting" out. Question - does the entire riser and elbow pipe need to come out to replace these or can it be done just pulling the elbow and both riser to elbow hose? (if the later, I would expect to replace all four rubber hose/couplers). Would appreciate feedback on proper procedure.
TIA.
(Sorry - having a problem getting pic to upload from PC. Will try from phone).
TIA.
