Just purchased a new outdrive for my 1993 5.0 LX 2655. Couldn't get a 1.50 ratio (as was on the boat previously) as they are supposedly on special order so I bought the 1.62 that the shop had in stock. The technician at the shop said there would be very little if any noticeable difference in speed and overall performance; he said at most I may need to change my prop. Anyone here have any similar experience or knowledge about this? Is the shop being truthful to me or do they just give me a sales pitch? Thanks.
What performance change can I expect?-gctid398805
I would use what Mercury Marine recommends.
Perhaps see if there is a web site that allows you to plug in numbers and determine engine/drive components.
Just curious... what did the drive cost you?
Going from the 1.47 (1.50) to the 1.62 will not be that noticeable.
You may need to up your prop pitch a little, but that depends on your WOT rpm's.
Install it and check your WOT rpm's - adjust pitch if needed.
Also as a side note, sometimes the 1.62 actually works a little better on marginal power 5.0 or 5.7 engines.
1.62 is a better ratio for the 5.0 in that boat anyways. You could run 1.84 and it would be OK. It would give you more prop options. I'm betting you probably run a 15 pitch with the 1.50. to get it to plane. 17 tops.
We can try props all day long, and never get things to work correctly and efficiently.
However, given that this is a 2655 w/ the 5.0L, I would agree with Jeff......, I do think that you'll be OK.
It sounds to me like he already owns the new 1.62:1 outdrive. If that's true, shouldn't any discussion from this point on should be directed to making it work for him?
Yep, that's why I posted; However, given that this is a 2655 w/ the 5.0L, I would agree with Jeff......, I do think that you'll be OK.
I took the boat out for a 6 hour trip on the weekend. It performed well on the new 1.62 ratio leg. I did notice it gained 200 or so rpm on and the engine can now push the prop past redline. I used the 15 x 17p prop I had on the 1.50 ratio outdrive so I will change it out to a 15 x 19. I think it will make things right.
