My 288 doesn't have a windlass so I very rarely anchor anywhere because of the challenge of manually droping/raising anchor especially if I'm on my own. I'm considering adding a windlass as the boat is already prewired for it but I got a quote from the show in the neighborhood of $2500-$3000 for the windlass & install. How much better/convenient is having a windlass for those of you who have them (especially in a boat like the 288 command bridge? Also, the shop recommends having a wireless control so I can operate it from the bow as they said that's the best place to control them so also curious if you all operate yours from up on the flybridge or if you go to the bow to operate the windlass?
Adding A Windlass
I can't imagine not having a windlass on mine. A wireless remote would be nice, but you'll still need to go out on the bow to secure the rode to the cleat, and unsecure it. So if you don't have foot controls, or don't want to install them, the remote would be even more valuable. It eliminates having to yell at someone at the helm to raise or lower the anchor. You should have wiring to the helms to operate the windlass if it's pre-wired. I have switches at both helms and foot controls on the bow, but no remote.
Jeff & Tara (And Hobie too)Lake Havasu City, AZ
|Current: 2022 Sun Tracker Sport Fish 22 XP3 w/ Mercury 200
And 13 others...
Thanks Jeff. So can you drop/raise your anchor if you by yourself on your 288 or do you need someone at the bow & someone at the helm?
- Likes 1
I have installed a windlass last year, i did it myself , it was quite a bit of work, but having windlass is awesome now!
I installed a helm control and bow controls as well, now wireless, don't really need it, but being able to control it from the bow is important
1998 Ciera 2855, 7.4L MPI, Harbourfront Toronto, Ontario
That price sounds about right for someone to do it all. I did my own with yachtman's help and it's not all that hard, just lots of variables. I skipped all the foot switch nonsense and went with a toggle in the cabin and remotes. You can substitute an ATV winch reversing solenoid for about 20 bucks and remotes are even less if you buy simple 12 volt remotes on Ebay. Yes, I have to face the disdain of snobby boaters for not using the ridiculous overpriced marine stuff, but I will just have to live with that. It's all 12 volt, it all works the same. So, I think I paid roughly 800 for the Maxwell windlass kit found on the interwebs, 40 bucks for the solenoid and remotes, the cost of the rode was like $400 (rope and chain) then you need appropriate power cables and decide on a power source. I went against everyone's advice and ran power from my house batteries in the back of the boat. Ideally, you want a dedicated battery very close to the windlass. You have to figure out a way to charge it. For whatever reason, mine works perfectly but it's not technically the way you should do it. Oh, the hardest part is drilling a big hole in your boat
Thanks for the reply everyone. I'm semi-handy but not to the point of risking screwing up this up due to the importance of placement and drilling the hole so glad to hear the quote I'm getting is in ballpark or reasonable for the amount of work involved. Guess I'm going ahead with it as I miss out on a lot of activities around here like taking the boat and anchoring in the prime spot for 4th of July fireworks & the annual Air & Water show or simply dropping anchor and chillaxing in the waters of Lake Michigan away from the marina because it's a pain to drop/raise the anchor manually.
And 13 others...
After a few things have been carefully considered, this is typically a user friendly installation. If you are fairly handy, you can install your Windlass.
The trick or main concerns will be layout, layout and more layout.
You get only one shot at it when it comes to cutting the deck correctly...... but it can be done!
Things to consider:
..... is the anchor rode locker large enough, and is it deep enough to create decent fall? if not, you may have trouble.
..... a Windlass can be more trouble-free and effective when the drop zone favors the AFT-most 1/3 of the rode locker.
..... many Horizontal Windlass styles incorporate spur gears for the reduction of which are not as stout as the Vertical Windlass that incorporates worm gears.
..... a Vertical Windlass "gypsy" offers approx 180* of rode contact, whereas a Horizontal Windlass "gypsy" offers approx 90* of contact only.
..... the below-deck electric motor of the Vertical Windlass does not hinder the rode pile........ if it did, the locker is too small to begin with.
..... the Vertical Windlass gypsy drops the rode offset from center of bow. (important to remember when doing the layout)
..... make sure that your anchor shank and swivel unit can lay nicely on your pulpit leaving some space just FWD of the gypsy.
.... choose an anchor that suits your anchoring needs, but one that can also come up and over the pulpit roller "hands-free" and from a low profile pull..... (your gypsy cannot stand up and pull/retrieve like a human is able to).
- Likes 1
http://www.ebay.com/itm/DC-12V-2CH-C...1%26rkt%3D1%26
Jeff I used something like this...works like a charm. I have one on my keys plus a spare. Just wire it to your reversing solenoid.
One thing to keep in mind when selecting your rode...how much line will you ever need ? Figure your depth X 3. As a land locked boater I will probably never anchor in water deeper than 30 feet. So, I will probably never use all the rode I am carrying. All chain is best, and also expensive, hence the chain/rope splice combo. Cheaper, weighs way less works fine for most recreational boating. I have spent lots of time learning how to properly place the anchor and still screw it up occasionally.
Hyperlite wrote:
Also , i put a chain stopper with mine, takes pressure of the windlass gears when docked
I seldom deploy my anchor when docked! :P :lol:
"2850Bounty" post=818185 wrote:
[color]blue wrote:
I seldom deploy my anchor when docked![/color] :P :lol:
The only time I needed another person to help anchor was when it was windy and there were other boats or land nearby. And my retract foot switch wasn't working. So I had to pull anchor and chain manually while calmly instructing the gf on the flybridge to manipulate the shifters and throttles so as not to run aground or ram any of the fancy Nordic tugs.
I also recommend the wireless remote in addition to helm switches. Foot switches seem to need maintenance every 5 years and it's always the retract one that stops working.
Esteban
Huntington Beach, California
2018 Element 16
My plan is to add a Lewmar V700 vertical and since this boat is prewired for the windlass and it was an option when new I'm assuming the anchor locker & drop are going to be good but that's why I'm having the marina do the work and come check it out first. Guess I'll also go w/ the recommended (by marina) wireless remote in addition to helm switch. Thanks everyone.
