2556 aluminum widow frames, paint or vinyl wrap?-gctid817086
    One thing i don't like on my 1990 2556 is the black colored aluminum widow frames( in and out). Would much rather have them aluminium or stainless style. The black paint is perhaps little faded outside, but otherwise in good condition. So my issue is purely cosmetic.
    Any one done a paint job on these, or other solution? Was thinking, regarding the inside, would a 3M vinyl wrap b an workable option? No idea how hard it would be compared to painting?
    Bayliner 2556 1990 project
    The same oxidation that's causing your paint issues will plague your vinyl just as bad (maybe worse). They can be painted and if you prep them properly they'll last many years.
    iBoatNW
      +1
        I'm going to redo mine when they make it high enough on the priority list. I was planning to remove them (need to replace tracks as well), sand them, and use Primacon before topcoat. That should work, yes?
        Bryan
        1997 2858 7.4 B2
        1992 Hewescraft
        Puyallup, WA
          If I were going to go to all the trouble of removing them, I would have them sand blasted and powder coated.
          Does anyone know what the original finish is?
          Esteban
          Huntington Beach, California
          2018 Element 16
            I have read most of the threads on filiform, but can't find the best way to remove filiform, before applying ACF 50. I was considering some Dremel tool attachment with a fine brush or one of those pen
            Take a look at the last post in this thread. I don't even own a travel trailer but landed on this looking for an answer to slight corrosion on an aluminum windowsill. I don't know the first thing about the process but the picture looks intriguing. It'll take more digging but might just be a good solituuion and the price doesn't seem terrible.
              Wonder is it even possible to remove the window frames on a 2556, look like they are(at least partly) holding up the fly bridge? Mine are not yet much corroded, just don like the black, makes the interior feeling a dark.
              About Primecon, have not used it but it, but think its a underwater primer before anti fouling paint, does not sound right in this application? Guess zinc chromate aluminum primer is the right stuff to prime the frames? Alternatively some 2K epoxy primers works well with aluminium. I need also to redo the track also, will be though as previous owner filled them with some sealer/silicone, can not even figure out the profile.....Side windows arenow totally glued solid.
                That's unfortunate if I had to choose a primer for the aluminum I'd go with an epoxy chromate. Used it a bunch in auto body, sticks to glass :silly:
                  "Sticks to glass". I remember you making that comment last year when I told you I was using DP40LF on my outdrive and prop. That stuff held up well on the outdrive, but part of my prop and most of my trim tabs were bare after last season. I used Primacon for the touching up this year.
                  Bryan
                  1997 2858 7.4 B2
                  1992 Hewescraft
                  Puyallup, WA
