Keys and horn-gctid816183
    Anyone know where I can get a new ignition key copied/made? Down to one, and one is none if it disappears.
    Also, any recommendations on a replacement horn, mine died.
    '96 Capri CL.
    Thanks!
    Z.
    walmart? or local hardware store? If not, I'd try a dealership
    Ontario
    2016 170BR
    90 HP
      If you have the numbers stamped on the key you should be able to find a duplicate on ebay.
      Doug
      Hanging Loose
      98 Carver 350 Mariner
      2013-
      KRUSTY KRAB
      2001 305
      5.7 BII
      2006-2013
        My locksmith copied mine for $1.50 each
        Captharv 2001 2452
