Depth Finder Problems-gctid816136
    The gauge that shows the depth on the dash was working at the beginning of the day and then it started to flash and wouldn't change from 8.2' deep. I tried to reset, turn the boat off and on and all that did is make it change to 0 depth and keep flashing. Any ideas?
    2002 Bayliner Capri Sport 195 Mercruiser 5.0L Alpha I Gen II
    Would help if we knew what kind of depth gauge you have. Is your transducer in-hull, though-hull, transom mount, etc. I've had similar problems with my in-hull mounted transducer. The transducer housing was leaking fluid.
