2000 Ciera 2855-gctid815258
    You should be able to unsnap the top from the arch and then pull the pins at the windshield frame of the front suppoers. This will allow you to fold it back from the front towards the arch. Let the canvas hang down and grab the edge with the snaps and wrap it under the framework towards the front of the boat and then up and over the framework. This will neatly wrap up the canvas around the framework. Put the cover/boot over the wrapped canvas. If you dont have a cover/boot then tie up the canvas with straps or bungies. I also wrap a bungie around each side to hold up the front supports you disconnected.
    Guest started a topic 2000 Ciera 2855-gctid815258
    I hope this is not a dumb question but I have a 2000 2855 Ciera LX Sunbridge. I'm not sure what to do with the polls for the beaming top,Can they collapsed back ?Do I have to physically take them out and take to beami top off? I really like to have it on there because my skin is not great in the sun. also i like to have exposure While we're out in the water not sure what to with everything. If you could send me some pictures I would appreciate it. I can't find anything online. That shows you what to do with the polls they look like the pins pullout and they collapse. But Like I said I would like to be able to collapse it towards the rear of the boatAnd then put it back up When I pull back in the dock. Any Advice would be greatly appreciated,I'm new to the boating world.
