Hi All - I recently bought a 97 Capri 1952, boat is running great! However, my ignition switch was spinning last time out, so I am having to replace it. With that known, I was worried that it could drain the battery if it got stuck in a position of power, so I disconnected my battery...without taking a quick pic (stupid). Pretty simple, the positive connection has just the main connector, but the negative has the main & what looks like an accessory connector (smaller/thinner connector). Does it matter which order I stack the neg connections?
Thanks in advance!
Thanks in advance!
