Ciera Sunbridge auxiliary fuel tank?-gctid814485
    I'm a newer owner of a 1991 2855 Ciera Sunbridge. It's got a 2nd gas fill pipe on the starboard side just above the swimstep which isn't connected to anything but I'm just curious if anyone else has this feature and if so where your auxiliary tank is located. Thoughts?
    You sure its for gasoline and not a waste tank deck fitting or something els??? That could be a disaster waiting to happen, I'd plug it off ASAP!
      One of the previous owners probably installed it and removed it.
      On second thought, that's probably where the original filler was and someone relocated it somewhere else and just left it instead of filling the hole.
      Esteban
      Huntington Beach, California
      2018 Element 16
        on my 3055 that is where the pump out fitting is.
        gas on one side and pump out on the other
