PLEASE HELP SUPPORT OUR SITE
Not sure about a bleed screw if there is one, but the small manual pump (3/4" cylinder) is on the side of the injector pump housing. Push it a few times and you'll feel it firm up as the pressure builds. Don't have a pic, but the cylinder is on the side on an angle.
Hope this helps. Cheers
John H
Brisbane QLD Aust "Harbor-nating" 2000 - 4788/Cummins 370's
CPL number is the build type, it is on the plate at the front left side of the block. It details the parts makeup of the engine.
Yours will be CPL 1975 which was installed from 2000 and newer. Bosch pump which does not have a bleed screw.
Bleed air by cracking each injector while turning over the engine or using the manual lift pump shown in the arrow. If you use the manual method
take a cord and pull UP the fuel solenoid to turn the fuel on and tie it off so fuel will flow. Don't forget to remove the cord before you try to start
the engine or you will wonder why it will not turn off. Fuel solenoid is the black boot on the right.
"Adios Dinero"
Photo Credit: Whiskywizard
