Hey folks, I'm planning on heading to Saturna Island next weekend and I want to get there using the Pender Canal between North and South Pender Island. I've never gone through so I'm having a look at the Navionics Web Chart. I see the channel markers so I assume it's passable. Just looks like it could get shallow on low tide so I just wanted to know if I need to watch tides coming through there or is it passable anytime of the tide cycle? Thanks.
Pender Canal-gctid812608
I went through a few times this spring, it's a bit narrow but doable. Been through there many times but this was the first time with the 35.
I went through when the tide was about 4 feet, my depth was reading as low as 9 feet at the shallowest point (probably a bit deeper than that overall) but that is close enough for my comfort level.
1995 Bayliner 3587
Twin Hino 250HP
Located In Sidney BC, Canada
I've been through many times with our 4788, I wouldn't go at low tide but otherwise it is fine. Just make sure to call out a securite' on the vhf before entering so others wait and you don't meet in the middle with nowhere to go and no room to pass.
1997 Pacific Mariner 65'- Permission Granted
Detroit Diesels 8v92TTA
NL Generators
1998 Novurania 430DL, 2021 70HP Yamaha
Formerly 2000 Bayliner 4788
Formerly 2001 Maxum 3300
Formerly 1996 Celebrity 265
No big issues. Plenty of room under the bridge. Keep an eye out for minus tides.
It's always appreciated when you make a securite call on 16 announcing your intentions, due to blind spots.
"Impasse". 2001 3988
Cummins 330's
Puget Sound
"You don't want to be the richest guy in the nursing home..."
I also consider the direction the tide is running when going through the Pender canal... as you have more control when heading into the current.. Last time I went through it was a flood and it was running from North to South. The boat going upstream must give way to the downstream one.
1979 32 Uniflite Sport Sedan twin 270 crusaders
2003 Bayliner 2152 210 Classic 5.0 mercruiser - sold
I wish I knew now what I didn't know then
Sea Venture
2000 3055, 5.7/B2, 18x23" props
Cruising the PNW and beyond.
DIYC, Riverhouse Marina
MMSI 316029971
Kirk
Drinks well with others.
