2004 Bayliner 2855 Stern Light-gctid812461
    The top section of my stern light was damaged during storage. Has anyone replaced? It is hard wired into the radar arch. I have limited electrical knowledge but could replace if its just connecting a few wires etc. Any help would be appreciated.
    Thank you,
    Get the one at Wally's world. Its only about $20. And yes, connecting wires works. However, as an electrical professional, buy a can of "liquid 'lectric tape" or similar. You can coat the splices with it and they are waterproof. A can is about $8 at Home depot.
    Captharv 2001 2452
      Thank you,
      Hi, just unscrew the panel on the underside of the radar arch to see the wires. You can easily cut the wires and fit a new unit using basic crimp, plug or soldering connections.
      There are plenty of options for sealing the connection with heat shrink or waterproof tape.
      Good luck
      Miff
      2002 Gen 3 2855 350 MPI Bravo 3
