2006 bayliner 175 prop replacement-gctid812290
  • 2006 bayliner 175 prop replacement-gctid812290
    Hey guys,
    So my boat prop decided to kiss a rock this weekend and now the prop needs to be replaced. It currently has a 20" pitch on right now.
    I found a 12.5x 23" aluminum prop.
    Would this prop work well with my bayliner? It has a merc 3.0l I believe 135 hp.
    Any info helps! Thank you !
    Usely 175 run with 3 blades 19 or 4 blades 17...you might be overyorwuing your engine with a 23
