Hello Everyone
If some could let me what size of packing I should be using for my 1990 3288 Bayliner with 150hp Hinos
Reason Im asking I just had the port engine repacked by my mechanic and it over heating 120 degrees at 1200 rpm and I have loosened the nut off until it almost falls off with only 4 threads left and there is only 2 pieces of Traditional waxed flax packing in the stuffing box , when I pull the nut right off water flows in
My Mechanic says on the port engine there is not enough room to push the nut forward and work in the 3 of flax packing ?
Any help or advice would be appreciated!
Thank you
Lars
Thank you
Lars
