Spot Light..move it to the arch?-gctid812192
    I have a 2011 Ciera 2855, Bravo III. 350 MPI. The spot light that came with the boat is mounted on the very front of the bow, slightly port of center. While using it, it reflects off the rail, anchor and the little amount of bow left in front of the light
    making it difficult to see ahead. I'm thinking of relocating it (or installing another one) on the arch therefore shinning it above those objects while looking forward. The arch on this boat slants forward, unlike the older models that slant toward the back. Anyone every done this before with success, or does it just just continue to shine on all those things with ambient light?
    As long as there is anything that will have light touch it anywhere near where you want to look, you will be blinded at night, and higher won't help. I had mine up on my roof, and it sucked! The entire bow, railings, even the windlass glare made night vision impossible.
    I have since added a 75W LED to my bow rail. No more blinding glare!
    Since you already have the wiring up there, it should be an easy addition.
    MMSI: 367637220
    HAM: KE7TTR
    TDI tech diver
    Kevin
      Great idea! Where did u get the light?
        I actually got the idea from mlewis100. Everything except the wire was from eBay. I was originally thinking of a spotlight on my bowsprit. This workout 1000 times better! http://www.baylinerownersclub.org/in...;s the thread.
        As to mounting it, I used Harley handlebar mirror clamps with a couple layers of inner tube to make up the difference and provide isolation between the two metals. Again, off eBay.
        [attachment]37381 wrote:
        BonDCBowLightClamps.jpg[/attachment]
        MMSI: 367637220
        HAM: KE7TTR
        TDI tech diver
        Kevin
