VR5 Boat Cover Gaps-gctid812102
My dealer's response about this when I brought it up was this was normal. It prevents the cover from rubbing against the tower in the event you trailer with the covers on and avoids damaging the cover or paint on the tower. They then also added that the cockpit was self bailing and that the speaker was waterproof. I told them this wasn't acceptable and want them to fix this.
This was there solution.
I'm also NOT a fan of having the second cockpit cover pole positioned right over the rear bench seat cooler, my dealer's solution was to provide me with a battery box lid to put on the cushion and have the pole sitting on it. I found my own solution and had them pay for them. I order two of these to replace the poles for the cockpit cover. These are pulleys suspension system for boat with towers. When I install them I'll post pics of them on my VR5
http://www.google.ca/url?sa=t&rct=j&...EMAeDtdg4uK6jA
The reponse is nonsense.
The real reason is that the covers are made after patterns and the boats differ in centimeters.
Therefore these cutouts must be very loose, otherwise it could happen that the cover couldn't be snapped on the boat.
Cutouts like these can't be waterproof by 100%, however the cutout can fit very good.
Close the gap like your dealer said and maybe combine it like we did here at a Sealine.
If its a bowrider version, then water will also flood in through the gaps either side of the walk through area, where the cockpit cover and the bow cover are fastened at the bottom of the screen, if you have fitted carpets then take them up or they will get soaked.
Current Boat: 2016 Bayliner VR6 4.5L 250
Previous Boat: 2015 Bayliner 175 3.0L TKS 135
Correct - Something I discovered after a week of raining and was able to gain access to inside the boat, I'll admit I was shocked to find that amount of water inside and due to visible water spots I could see that water did come in from that location you mentioned. I ordered my VR5 with the Grey flooring mat so water on floor isn't a big deal. But what happens now is water comes in front there (just one of the places it comes in) and flows over the in-floor ski locker and gets trapped inside the channel of the opening.
Same issue here with mine. Good idea with the tube. I think I'll drill and fit a 1/4" or 3/8" tube in the aft end of the channel running down to the pocket in the aft end of the ski locker.
Get the boat under canopy....problem, sleepless nights over...
Sometimes it "costs a lot to be THE man"
Wait until you find out that the "automatic bilge pump" is not really automatic...that will really crack your head wide open..
Lake Hartwell, GA
2012 BR 185 - 3.0 TKS
1987 SeaRay 300 - Twin 454’s
1995 Yamaha Waverunner III GP
1996 SeaDoo GTX
1999 SeaDoo GTX
Bjoern,
You are absolutely correct on one possible (probably the best) solution, however, these are circa 40k boats, so then to add the cost of obtaining a retro fit custom made all over cover is not ideal.
A similar modification Freechip had to his cover next to the tower fixing would also solve the front screen water Ingress problem, these modifications should be addressed at the manufacturing stage, rather than it being done later at the owners or if you are lucky the dealership costs.
Thanks everyone for your responses. Interesting on the pulleys, I will be interested to see those pictures when you get them installed. Honestly I think the whole rubbing against the boat/towers argument is BS. Bayliner should have covers designed for each boat model that fit snug and let minimal water in.
