Trophy Livewell.-gctid398044
    While boating, I noticed the livewell always has water in it. about a quarter full. The petcock on the fill is off and the only way I can figure its coming in is from the drain, as it is below the waterline. Could water be traveling up the tube and into the livewell? I wouldnt mind sealing it off as I never use it and really have no plans on using it. Has anyone had this issue and or sealed it off?
    Yes.
    Also, carefully inspect the hoses, valves and the seal between the deck and livewell. There were problems in these areas on some of the boats.
