So I have finished the new table for the boat I have been working on. I still need to fit the cup holders in place. But on the cherry cabinet paper cover it has developed bubbles. On the granite cabinet paper cover it is nice and smooth. Does anyone know how to get rid of the air bubbles in the contact paper? Then once that is completed does anyone know how to give it a hard protective coating? I thought of clear coating it but my fianc├® said ok but don't complain when the kids plates and or food slide off and hit your new carpet you just put in the boat.
securing and protecting new table top-gctid810983
As to a finish, is it paper or thin vinyl? You could do a decoupage with varnish and use those rubber mats to hold your plates on the table.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Sorry, my cell wouldn't transfer the photos. Anyway these are the photos of the table I made it out of 2, 2ft x 4ft pieces of plywood screwed together, sanded then sealed and covered with spray adhesive.
1994 Bayliner Capri 1850, 3 liter Mercruiser, 9.9 Johnson kicker.
1987 Wellcraft Antigua 265, Mercruiser 383 Stroker V8.
Pulls with Ext. Cab 2006 GMC Sierra 2500 HD
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
I just ranted and raved about this. I have a new phone and the photos are not being taken in the right format and it is a royal pain in @$$. I am sorry. It wont transfer. I failed.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Finally fixed the formatting on my cell phone photos. Here is the main photo I have left as I already put the table in the boat.
Hope you don't mind, but I recalibrate your photos so I could see them.
Since there is no coating that will stick to it, much less won't peel it off and/or lift and crinkle the paper, I suggest you get a sheet of ┬╝" plexiglass, cut it to size, cut out the cup holders and set it on top. Might want to make it slightly larger to protect the paper edges. Looking at the photos of the cupholders, the inserts may be all you need to hold the plexiglass in place.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Its self adhesive cabinet paper. I looks ok but could be way better. I agree that using plexiglass would be the way to go. Thank you for your input. I appreciate it.
