Hi all,
This week I picked up a (new to me) 1994 2452. I know the seller well and the boat has been taken care of during previous ownership. The boat has the generic 5.0 A1G2 set-up with 900 hours on the clock. To the best of my knowledge the boats been in fresh water its whole life, originating in Lake Michigan before finding its way up to Lake Superior where it will be used primarily. I have noticed a few things of interest while inspecting the boat:
1. The fuel tank has a manufacture date of 98 on it, I'm assuming it has been replaced?
2. The propeller installed is extremely low pitched. Also the blades are huge. During the test run the boat cavitated while going up on plane. The engine had no problem hitting max RPM, but getting out of the hole was difficult. Any suggestions for a more suitable prop for cruising. I'm planning on using a kicker for trolling so idle speed is of little concern.
3. The boat currently has a 15hp two stroke kicker mounted on a actuated tilt plate, but I would like to upgrade to a 4-stroke. I do have a 10 hp 4-stroke long shaft merc available, but do not know if that is enough motor to troll on. Any suggestions on minimum kicker size to comfortably control one of these things?
Thanks in advance for any advice!
