LED BULBS..AMAZON-gctid810847
I have tried sooo many different cheap led bulbs from amazon, so far pretty much all have so many that go bad they are proving to be a real pain. If anyone has a link to reasonably priced led bulbs please share. A mix of dimmable and not dimmable is best...
1997 Pacific Mariner 65'- Permission Granted
Detroit Diesels 8v92TTA
NL Generators
Novurania and Caribe RIBS, 50Merc and 60Yamaha
Formerly 2000 Bayliner 4788
Formerly 2001 Maxum 3300
Formerly 1996 Celebrity 265
Try superbright.com or innovativelight.com or ledlight.com
I bought mine at a Napa auto parts store and thus far have worked fine!
Not dimmable though! But I don't have any dimmable lights!
Still looking for a replacement Led for masthead light!
Good luck!
Don
1988 Bayliner 2455 (sold)
1976 Tahiti 16.5 I/O (sold)
I bought these for my courtesy lights. They work well in my 245.
Cutequeen 8PCS LED Car Lights Bulb White T10 3528 4-SMD 194 168 (pack of 8)
2003 Bayliner 245
2007 Sedona F21
I have tried so many it will make your head spin. The ones for the courtesy lights need to have the correct color rendition and not too bright. This is the best I have found, slightly whiter than the stock and also slightly brighter but they do look great. Cheap too. http://www.ebay.com/itm/10x-LED-Warm...item4af666526b
Seems we may have different bulb types. The 4788 standard bases us G4 bulbs, and I think there are around 70 of them... a buck or two a piece is cool but I have seen some of the better places charging $10++/bulb...
NL Generators
I have bought cheap G4 LED's off Amazon and have never had even one bulb go bad. Zero, nada
www.boatyardgm.com
www.pacificyachtimports.net
2002 Carver Voyager 57
"Making Waves"
3988 250 Hinos
"The Dark Side"
Alameda, California
1992 3288, twin Hino 150's sold
S. Puget Sound
I replaced ten light fixtures that had the old fluorescent light bulbs or the older 12 volt bulbs and replaced the festoon bulbs in the ceiling lights I wanted to keep.
All were bought on ebay and have held up nicely for two years. I can't complain about the price either.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
They come in several different sizes. I looked back at last years order and they were 42mm and that covered all the festoons. Most if not all the festoon bulbs will be for ceiling lights but I also used the 42mm festoon on the red and green nav lights too. Pull one out and check. You never know what size bulb Bayliner used that day.
Dan
Claudia V. III
1988 - 3218
Gas Drives
