I bring this to the forum as information only, not an endorsement of the supplier.
Micron Ratings in Filters
A MICRON (or 1 micrometer) is a length of measurement used by filter manufacturers to measure the diameter of a particle. Fluid filters can have a micron rating which expresses the filter's ability to remove contaminants based on the size of the particles. For example, a filter rated for "twenty (20) microns" means that the filter will capture and contain all particles in the fluid that are 20 microns and larger in diameter.
1 Micron equals .001 mm or .000039 inches
2 Microns is the size of BACTERIA
8 Microns is the size of RED BLOOD CELLS
25 Microns is the size of WHITE BLOOD CELLS
40 Microns is VISIBLE WITH THE NAKED EYE
70 Microns is the size of DIAMETER OF A HUMAN HAIR
Measuring a micron rating through testing can be done through three methods:
Nominal Micron Rating means that the filter can capture a given percentage of particles of the stated size. For example, a nominal micron rating of 10 microns at 95% means that the filter media retains 95% of the particles that are 10 microns and larger.
Absolute Micron Rating means that the filter is tested using a single pass of contaminants through a filter media and any particles that pass through are measured. You could end up with a 96.7% retention of that micron number.
Multipass Beta Ratio Testing is the most accurate method of rating filters. Measured samples of the fluid are then taken at timed intervals from both the downstream and the upstream of the filter simultaneously, particles are measured and counted by electronic means using automatic particles counters. From these measurements a Beta Ratio (b) is formulated by dividing the number of particles of a particular size in the upstream flow by the number of particles of the same size in the downstream flow, and is an indicator of how well a filter stops a particulate. For example, if one out of every two particles in the fluid pass through the filter, the beta ratio is 2; if one out of every 200 of the particles pass through the filter the beta ratio is 200. Therefore, filters with a higher beta ratio retain more particles and have higher efficiency.
For a NapaGold by Wix 1748, the nominal micron rating is 35, and the beta ratio is 2/20 = 10/22, which means that the filter will capture 50% of the 10 micron particles and 95% of the 22 micron particles (see NapaGold by Wix 51748 or Napa 1748).
Beta Ratio Efficiency
1.00 0.00 %
1.50 33.00 %
2.00 50.00 %
10.00 90.00 %
20.00 95.00 %
50.00 98.00 %
75.00 98.70 %
100.00 99.00 %
200.00 99.50 %
1000.00 99.90 %
10000.00 99.99 %
Many filter manufacturers will try to offer the ratings on their filters, but most do not. Of the four brands FleetFilter.com sells (NapaGold by Wix, Fram, Luberfiner, Baldwin), only Wix publishes a nominal micron rating and a beta ratio of most of their filters.
I hope this article answers questions ÔÇô a more knowledgeable customer can make better choices. Thank you for choosing FleetFilter.com!
1.00 0.00 %
1.50 33.00 %
2.00 50.00 %
10.00 90.00 %
20.00 95.00 %
50.00 98.00 %
75.00 98.70 %
100.00 99.00 %
200.00 99.50 %
1000.00 99.90 %
10000.00 99.99 %
