I am about to install my gauges and I have chosen to connect them almost directly to the outlet ports on the top of the housings. My thinking was that although I would like to run vacuum lines to the helm and be able to check the vacuum pressure periodically from there, if I install them right at the filter housings then that will force me to do my checks from the aft stateroom "flip up shelf" and thereby make a more meaningful check of everything else while I am there. Does anyone have any experience with installing them right on the housing? The housings are not the newer T-bolt on the top types see attachment. Thanks
