We just bought a beautiful 2000 3988. Unfortunately, it is too long for our slip and we need to remove the bow sprit. Does anyone know what kind of adhesive was used and how to remove it. We have removed the bolts but can't budge the bow sprit.
Removing the bow sprit on a 3988-gctid808801
I just purchased a 2001 3988 and was faced with the exact same issue. I had a good buddy helping me and this is how we did it: We spun the boat around so that we could work off of the dock. We removed the bolts, (not a big problem). We then popped the bow sprit rail off using a rubber mallet, (be sure to remove the set screws if they're present). Now the difficult part came because of the adhesive used. Luckily, my buddy brought a decent size metal wedge, which really did the trick. We started by using a couple of screw drivers and carefully pounded them in to break up the leading edge of adhesive. Once we created enough room, we introduced the metal wedge and carefully pounded it in, ( it took some forceful whacks to accomplish our goal). We could hear the adhesive slowly starting to peal away. We took our time using the wedge across the leading edge, pounding it deeper each time; we would also push up on the pulpit occasionally in order to separate it from the bow. The bow sprit eventually separated and we were pleased that there was virtually no damage done to the boat.
Having read a thread on the forum about this, we were also equipped to use wire saws, but the method we chose worked great and we never used the saws. Other members have also mentioned using a hydraulic jack, off of the dock, to apply upward pressure.
There are also some good threads on the forum regarding fabricating a new bow sprit using Starboard; this is my next project.
If you're interested in talking about it, give me a call on my cell at 714-928-1112; leave a message if I don't pick up.
Good luck!!
Alex
Alex
Orange County, Ca.
2001 3988
Twin Cummins 330's
Here is the job I did on my 3388. Had a buddy help me out. Worked out well.
http://baylinerownersclub.org/index....l-modification
Terry
1999 Bayliner 3388
Twin Cummins 4BTA
Fisherman, Cruiser, Boaticus-enthusiasticus-maximus
Member Royal Victoria Yacht Club
Flamingo, I'm glad it worked out!! I'm currently looking to fabricate a replacement pulpit, using the Starboard material. I still need to prep the bow by scrapping off the adhesive and some minor repair using epoxy; however, my plan is to fabricate a new and substantially shorted pulpit using the Starboard material. I'll post pictures along the way. Let me know what your plan is and please share any words of wisdom along the way.
Alex
Orange County, Ca.
2001 3988
Twin Cummins 330's
