Where to Mount Transducer - Tahoe Q4 Sport-gctid808483
  • Where to Mount Transducer - Tahoe Q4 Sport-gctid808483
    Hi all,
    I am based in Australia and recently had a Tahoe Q4 Sport imported. I am a first time boat owner and i have taken the boat to the installer to get a Garmin CHIRP Echomap 75SV installed. The unit comes with a transom mount, however the installer has stated because this is a sports boat it cant be mounted on the transom and would most likely fall off or become damaged. He has suggested i purchase a thru hull transducer instead however these are very costly especially considering i would need to get a pair due to the shape of the hull.
    I know this is a bayliner forum but struggling to validate this and understand what my options may be. The back of my boat is not flat, and is rounded/curved given it is a sports boat.
    Thanks.
    Think he's trying to sell you a ducer you don't really need. A through hull ducer would be preferable but as you've found out they are $pendy. Mount it on the transom, it's likely adjustable to compensate for the curve, and don't let anybody abuse it with water toys.
      Hi. Thanks for the reply. I wouldnt be buying the transducer from him, id get it from my local store. He was uneasy about mounting on transom...
        Essentially i was told the following:
        - The boat is a sports boat and transom is curved meaning the mount wont be stable. He stated that there is a good chance it will fall off or become damaged. Also being so close to the propeller of such a boat, there will be interference. Suggested i look into a through hull solution but these are just way out of budget.
        To be honest all i really need is a depth reading and GPS. Does such a unit exist? I don't fish, so i don't extremely detailed sonar, it's more a nice to have.
        Thanks.
          I put one of these on my 1800. Stuck the ducer in the bilge with a sandbag to hold it in place, poured a bucket of water in the bilge to keep the ducer submerged. Worked flawlessly. Never did permanently mount it, used it like that for years
