I picked up a Garmin 18xHD radome to install on my 2007 285 Cierra. Running wires was no problem, but physically mounting the dome is tricky. The arch doesn't offer much space inside it for nuts and bolts, and I am certainly not going to be able to reach nuts inside the arch with the standard Garmin 9in square bolting pattern, without cutting a bigger access hatch. I was thinking of getting a SeaView mount, which mounts with a 5 inch square pattern. I might be able to do that without cutting a bigger hatch.
How have others mounted radar on their Bayliner arches?
