Deadrise on a 1985 Trophy 2160 or Ciera 2150-gctid806979
    Looking at picking up a used trailer, a Venture dual axle, aluminum frame with bunks. The boat that was on it had a 19 degree deadrise. Just want to make sure it's close enough to that so I know I can adjust it to fit.
    So, if anyone has the the deadrise of a 1985 Trophy 2160 or a Cierra 2150 (same hull), I'd appreciated it.
    I think it's around 20 degrees. No more than 22 degrees for sure.
    Matt Train
    BOC Site Team
    Chicagoland, IL
      Thanks Matt, that's what I figured too, just wanted to check with the brain trust.
        Well you will have to settle for me instead, as I have neither of those qualities.
        Matt Train
        BOC Site Team
        Chicagoland, IL
