Can anyone assist, I need to know what size the drain plug bolt is in my 2002 3055
drain plug size on 3055-gctid805371
"aquaholic13" post=805410 wrote:
Most standard plugs are 1/2" NPT thread. The NPT stands for National Pipe Thread.
"THE FIX"
'93 2556
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
Hi Gazza25. When you install the new brass plug, be sure to grease the threads. It will help when you remove the plug next time. Good luck, Griff
I wonder when they started putting drain plugs in 3055's. My 1999 3055 did not have a drain plug so I never had to worry about forgetting to put it in.
Rick Grew
1981 Carver 3007 Aft Cabin
2004 Past Commodore
2021 Commodore
www.wrycc.com
"Jhs3750" post=805696 wrote:
You certain you don't have a plug?
My 2000 has one -
Rick Grew
2004 Past Commodore
2021 Commodore
www.wrycc.com
