Bought my 2255 bayliner 5.7 mercruiser a year ago. Never had any issues with the idle last year (once it died idling coming into a dock). This year I can't seem to get the idle correct. I set the idle screw to 750rpms & it will die if I put it in gear. I turn the idle up to where I can actually put it in gear without it dying & its between 1100 & 1500 rpms. ( a little nerve racking when docking & putting it in gear). When i do set the idle to 750 or so it seems to bounce around 100 rpms or so. It has a Rochester 4 barrel. Thinking a vacuum leak or a carb rebuild/cleaning, any ideas? Thx
