Any suggestions on engine cover insulation.What is there now is 394 mill thick.Would like around 1"thick.The boat has an engine box not a hatch.
Reducing engine noise-gctid803816
https://www.amazon.com/gp/product/B0...oop_bw_c_x_1_w
I see the price came down. Lucky you!
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
There is an outfit in MA called Soundown that has a good variety of marine sound absorbing materials. There is also a company in Tigard, Oregon that manufactures sound absorbing materials but I can't remember the name. If it comes to me I'll edit this post
Greg
It is called Composite Barriers / Sound Technology
Newport, Oregon
South Beach Marina
As well as choosing a good sound deadening material (something with lead in it works well BTW), consider also any openings to the engine which may transmit noise. Our old boat had a Greymarine flathead six which was actually very quiet what with the valve train buried within the engine block.
We replaced the Grey marine with a 4 cylinder Ford diesel Osco conversion and it was LOUD to say the least. Adding tons of noise reducing foam help significantly, but plugging holes that allowed sound to filter out of the bilge helped reduce the sound considerably. Had we done the same with the Greymarine, it would have been nearly silent.
2007 Discovery 246
300mpi BIII
Welcome island Lake Superior
