Wednesday I drove to the marina where my boat is winter stored. I removed all the shrinkwrap and prepped the boat for my 2017 launch. I stopped at the marina office to make an appointment to launch yesterday, Thursday at 11 AM. I then went out for lunch.
I arrived back at the boat. I then decided it would be a good idea to turn the engines over. I turned the key for the starboard engine and it cranked over as it should have. I then turned the key for the port engine and nothing, nada, zip, zilch. Nothing happened.
I took a quick check below in the engine compartment but I could not see anything out of the ordinary. Now, it was my port transmission that had been rebuilt and they had to pull the engine so they could remove the transmission to effect the rebuild.
I am thinking that when they reinstalled the engine and transmission something was not reconnected. I am hoping that it is something that simple. I can't think of anything else it could be. Both engines turned over in December and January when I went to check on them so it is only after the engine removal that it will not start.
A friend of mine suggested that I wiggle the shifter at the helm with the key turned on to the start position to make sure the neutral switch is working. I did that turning the key into the start position while moving the shift lever all the way forward and aft. Nothing happened.
Both batteries are fine so it's not the batteries. So, everyone please keep your fingers crossed that they will find and solve the problem. I am looking forward to hitting the water and getting my dock set up at my new marina.
Obviously any ideas or suggestions from members here are greatly appreciated. I will head back to the boat on Saturday.
Hoping to launch soon.
