Lower Unit Install Help-gctid803309
    I took my lower unit off to inspect my impeller (it was fine), and then reassembled everything. I went to put the lower unit back on and I have a 1/4" to a 1/2" gap now between the lower and upper unit. I have been trying for about 2 hours now to get it back on and still no luck.... HELP.... This is driving me nuts! I cant figure it out!
    Forgot to mention, the motor is a 1996 Mercury Force 120!
      Well with all of the overwhelming responses..... I figured it out! Had to rotate my shift shaft slightly to get it in gear, and then the lower unit slid in fine.
        I saw your initial post but I am not familiar with the alpha shift linkage or impeller portion of that drive so I didn't have anything to offer. Glad you got it figured out and it turned out to be a minor thing.
          No worries Builderdude, my comment wasn't directed at anyone specifically. Just wanted to share my success!
            Take heart.Some one will have the same problem next weekend.Thanks to you we know how to close that capp in just a few minutes instead of hours.thanks
              THanks for the kind words 360 Mafia, much appreciated!
