Need help? Open front deck storage..... water stay inside, wth is that?
discovery 192 cuddy cab-gctid803033
Same thing for me (same boat).. After buying last week the boat, we had to drive for about 10 hrs with torrential rain when we arrived in the Lower mainland..
Sucked the water under the anchor storage, and will need to test when the weather is getting better (soon?)..
I suspect the drain connector may not be tighten enough and/or the drain may be clogged up.. Will try to the wife with water hose spraying/flood the anchor storage and I will watch the storage..
