Im looking at purchasing a 1998 Ciera 2858 that needs some work.. Boat has been sitting for years.. Im a good mechaninc and not much scares me except fiberglass work... Can anyone tell me where the fuel tank is located on this particular boat. is it glassed into the floor.. If it leaks, is it easy to replace? Help! is it steel or aluminum?
1998 2858 Ciera fuel tank-gctid802561
The tank is behind the engine against the bulkhead, you can see it from the engine bay, you will notice as you step into boat and down, there are a couple of steps, this is actually the fuel tank you are walking over.
I am not sure how it comes out i but i would imagine you would need to dismantle the internal step to gain access all around it, it would no doubt mean cutting lots of fibre glass i can imagine, its all hidden with carpet so you could easily hide the repair.
I would imagine this is hell of a job to get out!
It'll be similar to mine. See my thread, IMO big job!
Don't think 10' door height will be enough, even with the arch removed. My 2556 is 12' to the top of the bridge ladder while on the trailer
