How to attach those long decorative strips inside the cabin-gctid800781
My experience. They were held in with stainless screws from the outside, along the same line as your bumper strip. Extra screws along the path taken to join the two half's of the boat together.
Crash Override
1989 Bayliner 2455
Ford 351W (5.8l) OMC Cobra
Mods: Custom pulpit, 8 million candle power of LED lighting, Lowrance Hook 5, Uniden UM380BK VHF w/8' Whip, Custom 3,000lb cable drive winch w/150 cable+rode, Sound system, upgraded sleeping quarters.
in looking at your images it appears that there are screw holes on the line where the two halves meet. Maybe slip a ice pick through one to see if it comes out behind the rub rail insert and look at the back of the trim board and see if that is the spot where it was secured. By chance can you take a picture of the back side of the trim panels?
PS, I'm trying to figure out how to remove mine from my 2004 285 so this might be a answer to my quest too.
2004 Bayliner 285 350 MPI Bravo III
2007 Bayliner 192 Discovery 3.0 135HP (sold)
2000 Ciera 2455 sold
Redmond, Washington
The one on the Left (Wet) Coast
"Chuck Wagon" post=800812 wrote:
The back of these trim boards have no mounting holes across the whole span. I'm thinking maybe the P/O had them redone but never mounted them back.. So they just grind the screws down so no one gets hurt and leave it.
I have mine off right now. I intend on replacing them with some nice cedar strips when it goes back together. I'll be grinding the holes down and using "pl premium" to put the new ones on.
Crash Override
1989 Bayliner 2455
"Chuck Wagon" post=800944 wrote:
That sounds really nice. I'm going to investigate what else I can use to mount these strips and have a clean installed look. I prefer a more non-invasive method. Would love to see your project when its completed. What is "pl premium" ?
Here's a link to the product. https://www.lowes.ca/construction-ad..._g1196140.html
Crash Override
1989 Bayliner 2455
"What is "pl premium"
Construction adhesive in a tube.
I need to take mine off to repair a bow rail stanchion that got crunched. It really makes me scratch my head why these are attached from behind the rub rail, what a PITA. Considering my rub rail insert end joint is at the stern I need to pull it up one side nearly to the anchor to get this stupid trim panel off,oh well sounds like at least a half rack project on a warm day LOL. :S
Anyone have a idea of how to identify the "long" screws that hold on the trim panel?
Redmond, Washington
I'd say it's easier to find the screw points inside and carefully pry them off, without accessing the screws from the outside at all. That was my choice anyway.
MikeCrash Override
1989 Bayliner 2455
"I'd say it's easier to find the screw points inside and carefully pry them off, without accessing the screws from the outside at all. That was my choice anyway."
Sounds like you have been there done that. If I can locate the screws and pry off the trim panel without destroying it to roll back the headliner, how did you re mount the trim board from the inside?
Redmond, Washington
If your careful it can be done. I wasn't careful because I didn't care to keep the old ones, and I only cracked on spot.. Go figure.
Once out.. Drill the screw holes in the panels with a larger bit, using them as mounting points. Then use a very liberal amount of pl premium to stick it back on.
MikeCrash Override
1989 Bayliner 2455
Just saw this one... I'll take some pictures of how it goes together for you tomorrow.
PS, I'm trying to figure out how to remove mine from my 2004 285 so this might be a answer to my quest too.Crash Override
1989 Bayliner 2455
