Hurth 360a transmission rebuld-gctid800730
    Hi
    I had trouble with my hurth hbw 360a transmission in my 1987 3270 slow shifting in forward. Most all the info that I could find out about repairing this was on this site, saying it was thrust washer gone. Pulled it out and took it apart and sure enough thrust washer wore. Replaced the parts and put it back together and on the bench shifting forward and rev it don't want to snap in forward like it do reverse, adjusted the cover as needed and it still bearly wants to fall in gear. Any help would be appreciated. Thanks
    https://www.harbormarine.net/pdf/hbw...epair_tech.pdf
    If you go here, you can download the repair manual. You might also try calling Mike at Harbor Marine. He knows those trannys inside and out.
      Welcome! Mike is your guy. He's worth waiting for if you are on hold.
      Please fill out some of your personal information about your boat, where you live, etc. it's highly likely there's a BOC member nearby.
