Gas Tank capacity?????-gctid396716
    There should be a label on the tank from the manufacturer noting the total capacity of the tank. NOTE: The fuel pick-up does not extend to the lowest point inside of the tank so you will not benefit from the total capacity of the tank.
  • Alaskanmutt
    Pop the inspection plate infront of the engine well, it is on a label there, but it is 82 gallons if it is stock.
    usually there's a label on the tank close to where filler/vent hoses and gauge are installed....
    Are all your gauges dead? If so I assume that the ground is gone (the lights won't work either) or that you have a blown fuse.
    how big is your boat? Mine is an 82 gallon tank. Check out the owners lists and look at the trophy 2002 WA section. And post some pics!
    Guest started a topic Gas Tank capacity?????-gctid396716
    Have a 93 Bayliner Trophy Cuddy W/A - It is all original so I am wondering if anyone out there knows how much the gas tank holds???
    None of the gauges work so i really am gambling every time out guessing how much gas is actually in the tank
    Any thoughts on the capacity and how to get the gauges to work???
