sticky sliding windows-gctid796984
    I have a 1988 3888 Bayliner motoryacht.
    Several of the windows (sliders) are stuck, won't slide.
    Any suggestions on how to get them loose and lubricated ?
    If they have been closed for a long time I have had good luck spraying them with WD40 at the bottom and top. Let it sit over night and try it the next day.
    Gibraltar, Mi.
    1986- 3870- Hino 175's - Just purchased May ,2017
    34' Tollycraft- sold
    88 26' Shamrock/ Diesel
    14' Zodiac Bay Runner
      Silicone spray would may be a good option as well. Not sure if wd40 would deteriorate the rubber.
      "Martini's Law"
      Nova Scotia, Canada
        Was thinking silicone would be better than WD 40
        Silicone is a lubricant
        WD 40 is a solvent
        Just not sure if it would penetrate and loosen the sticky areas.
        Just seeing if there were any better ideas.
        Thanks for the help
          One of my spring projects is to replace the "fuzzies" on my 3818. The sliders move but only a few inches. I had a similar issue with my '72 Nova Windows and the only viable situation was to replace the fuzzies. You may need to do the same on yours. It looks like more labor than cost of materials, but first it either has to stop raining or I need to borrow a boat house.
          1988 3818 "GLAUBEN
            I just did this when I bought my boat (last week). I used silicone oil from O'Reilly's along the bottom rail, slid it back and forth. Another layer, slid again then waited 20 minutes. Repeat. Now it's fine. My boat is pretty beat up, barely sea-worthy so I'm going to be asking the forum alot of questions.
              The addition of anything other than a "dry" lubricant will certainly attract contaminants and you're back to the same issue in the future. Try something with a "Dry Moly" once sprayed, the lubricant will dry and not retain any liquid properties which will hold onto anything that touches it,.....dirt, insects, monkey fur, etc..
              Hell, Michigan (yes we really live in a city named "Hell" in Michigan)
              2012 BR 185 - 3.0 TKS
              1985 Harris Flotebote Classic 240
              1995 Yamaha Waverunner III GP
