I Have a 1981 Bayliner 32 ft with Volvo AQ151 4 cyl. inboards. At High rpms, the raw water system sprays water onto my distributor at the sea strainer fitting. ( so I am told ) Is there any way to fix this besides replacing the cylindwer head as the mechanic suggests quoting pressure build up? How does a fresh water system cause pressure in the raw water system ??? Help.
Roy Kelln
5 o'Clock
Roy Kelln
5 o'Clock
