complete air cond. kit for 2655-gctid347012
    guys where can i get a great price on a complete new air conditioning kit for my 2655 ?? new .
    Mermaid Manufacturing. I believe it is www.mmair.com.. Call and ask for Brian.
    Tony, Cape Cod, MA
    Vice Commodore Bourne Yacht Club
    1994 Carver 390 Cockpit Motor Yacht
    454 Merc Cruisers inboards
    "HOLODECK"
    2014 10' hard bottomed Dink powered by 3.3HP Mariner 2 stroke
    www.bourneyachtclub.com
      Great to deal with. Everything you need is in kit. I installed one in my 2655
        thank you for responding fellas , i knew where to ask . ill give this Brian guy a call .
          tell him Tony referred you, (NO, I do NOT get a commission!) I have the Mermaid 12,000 unit in my 2850 Contessa with the X controller. Just a WONDERFUL unit with reverse cycle. Brian is GREAT to deal with!
          Tony, Cape Cod, MA
          "HOLODECK"
            Bad news guys, Brian is no longer with the co. ! they refered me to a new guy who didnt really know his *** from China. so i did some research online and found an entire kit for a 6500 btu new same brand with pump from Starmarine, under $ 1600 with shipping. Anyone familiar with these guys??
              The price sounds a bit high. Does it have reverse cycle? I think you woudl want a bigger unit. Check out DEFENDER.COM They also carry Mermaid units. Sad to hear Brian is no longer there. he was a wealth of info!
              Tony, Cape Cod, MA
              "HOLODECK"
                If you can get the whole thing including install kit for under $1600 I would buy it. I had the exact unit for 10 years. It had electric heat. Top discharge. Installed myself.
                http://"http://www.defender.com/prod...13257&id=48360
                  no guys that does not include reverse heat or the install. that is just for the unit, kit, and pump, i think i still have to buy the thermostat too. that is the cheapest i have found for a new unit. If this sounds high to you guys , HELP. I cant find it any cheaper , my local guy at skipper Buds here in Chicago area said beat he could do for same unit was 2300, not including install.
                    Now's the time to buy. Off season. Install kit is $342.99 http://"http://www.defender.com/prod...13258&id=48462
                    6500 BTU Cool with heat $1299.99 http://"http://www.defender.com/prod...13257&id=48360
                    Total Price $1642.00 Looks like Pump + T-stat is extra
                      yes , msd , thats where im at . and actually starmarine has the 6500 unit at $1047.00 . I believe that is as good as it gets . If i wanted to add the reverse heat it is only $100.00 more , im kind of considering it . Thanks for all responses!
                        Scraping B wrote:
                        yes , msd , thats where im at . and actually starmarine has the 6500 unit at $1047.00 . I believe that is as good as it gets . If i wanted to add the reverse [COLOR]"#0000CD" wrote:
                        heat it is only $100.00 more[/COLOR]
                        Get heat. Its a no brainer. Make sure you get top discharge model.
                          I have the 12,500 BTU unit with reverse cycle, paid $1299.00 INCLUDING the FX-1 controller. Darned you Brian!
                          Yes, get the reverse cycle for the small amount of extra $$. WELL WORTH it!
                          Tony, Cape Cod, MA
                          "HOLODECK"
                            How did the install go?
                            I am strongly considering adding A/C to my 1999 2655, hovering my credit card over the ordering page.
                            Where did you put the components? I'd probably be looking at a 7000BTU unit, and I'm not seeing any easy place it will fit other than the space behind the refrigerator. Which would then likely have it's main output right across the top step, which is probably suitable for cooling both sleeping areas fairly. I suspect it wouldn't be too hard to get everything routed from there.
                            Opinions?
                              Re ordering from Mermaid, I live in Toronto Canada and had ordered a 6500 btu with electric heat and installation kit delivered to a depot in Niagara Falls New York for pickup, they're in Florida.
                              I've been dissapointed with the experience and have gone back and forth with the support desk, I get the feeling they think I'm a pain to deal with. The unit freezes up. In the end was told the marine pump wasn't strong enough to reach the unit at the front of the boat from the engine room. I found another Marche pump locally which sends enough water, but the unit still freezes up. I now have to contact again and arrange to send the unit back for remedy once the boat comes out of the water in the fall.
                              I guess what bothers me most is that I sent the schematics from Bayliner with runs displayed and they didn't take the time to ensure what they sold me would work. Besides supplying a pump that wouldn't pump enough for the required run, the kit had a breaker switch marked as shipped which wasn't, I suggested they didn't need to as I had one; the through hull wouldn't fit into the ball valve, I had to purchase another (the unit I purchased had a grounding screw, what they sent didn't), there was something else missing that I had to purchase locally but can't remember now..
                              Anyway, not a good experience, but lesson learned, do more homework than I did. Tread carefully with this company.
