I have been using Mobil 1 15w 50 in my boats forever however it seems impossible to find any where locally in Canada now a days. I can easily get Rotella T 15w 40 which has been recommended on several sites for Mercruiser engines. I know it is not synthetic oil but I do change about every 50-60 hrs so I guess it should be more than fine. Any comments on using Rotella T? Link to oil. http://www.shell.com/home/content/ro...ducts/tpl_pro/
Rotella T 15w 40-gctid391604
I use Rotella also... Good stuff. Many local car/truck dealerships use it as well. I saw 55 gallon drums of it behind the Ford dealer this past Tuesday.
Doug ;}
MMSI: 338068776
sigpic
I use the 15W40 Rotella T in all my diesel engines, marine and ashore. I buy the 20L pails. Walmart's regular retail price is better, but Canadian Tire's price is better if you catch a sale.
On the boat, I analyze the 3 engines annually and change when the lab says I'm getting close. The land-based equipment gets changed annually - I will start analyzing this year.
my dad used rotella for decades in all our cars and his semi trucks. I still use it today in most of my cars, except my civic. Good stuff, np finding it around here
One thing to remember when switching oils....Is your new oil a higher detergent than your past oils. Our company switched to a higher detergent oil recently. We were finding out than it was REALLY cleaning the engines out, and plugging the oil filters, causing the oil to bypass the filters. When you notice your oil pressure dropping and engine temp running a bit higher than normal,your filter is getting clogged, usually takes a couple of filter changes to solve the issue.
No problem in gas engines and in fact is commonly used in the motorcycle world. This oil is designed for both gas and diesel applications. http://kozmik.guelph.on.ca/gtdprojec...shell_t_us.pdf
Look at the specs, some versions of both Rotella and Delo are specified for both gas and diesel. I use Chevron Delo 400 straight weight. Rotella would be fine, you can use straight 30 or 40 or even the 15w/40. I think that Crusader now recommends the 15w/40 in its gas inboards so that should be fine. Only time I'd stick with the Merc oil is if I had new engine under warrantee.
Long Island Sound Region
