Gas mileage on my 1994 2252 mercruiser 4.3-gctid757276
    What im I going to get (gas mileage ) on my 1994 2252 cuddy 4.3 mercruiser? Thanks
    I have a 185 with a 4.3...smaller than your and I get 4.5 MPGUS or 5.3 us gallon/hr.
    You will probably get less than that.
    This based on my first 50 hrs with my new boat.
      Same engine, but fuel injected. Yours may not be. On my 195 at best economy speed about 5mpg, but since I don't go that fast I normally get 4 mpg including no wake zones, stopping and starting again a few times. Hard question to answer, just like it is for a car. For a boat, wind is a bigger factor and current is also an issue if you are talking mpg over the ground rather than relative to the water. More like an airplane than a ground vehicle. It depends on the conditions. If you keep close track of fuel consumption and use a phone app like speedpro+ you can get a pretty good idea if it's mpg over ground that you are interested in. If you want to squeeze that last 10% out of your boat you're obsessing, IMHO.
      Bayliner 195 Bowrider 2013 4.3l 220hp MPI
      Alpha 1, Gen II
      2012 Toyota Highlander V6 4wd with tow package
      Albany, Ohio
      MMSI: 338234042
      Less than 200 days until retirement.
      Beware the men of measured merriment
      (Sinclair Lewis, Arrowsmith, paraphrased)
