Hello all, i had posted some questions about my bayliner not being able to top 27 knts as reported by g.p.s. and being very slow coming up on plane. you all were wonderful and gave several tips. so here's the deal......my engine is a.o.k. runs between 110 and 150 degrees. timing is good and carb is clean enough. plugs are good and she runs strong. outdrive is good with no issue's. just pulled the boat and my prop size is 14.5 by 19. hull is clean.
i will be adding a planing fin to outdrive. any thoughts as to proper prop size. boat weighs about 5500 pounds dry, so figure gas and 4 people at 200 pnds and another 100 for odd's and ends.
one final clue. yesterday going up the navasink i had 5 on board and we were all seated on the l shaped seat and one person stood behind it on deck. i also had a cooler in back full of ice and soda. boat would not do more than 9 knts at 3500 rpm showing and throttle firewalled, and bow wouldn't come down. i know stern heavy. i moved cooler to front of cabin and had 2 guests sit up on cabin by hatch and bingo she came right up on plane. took about 50 seconds to reach 25 knts. i have called a couple of bayliner dealers and they can't be bothered to give me any advice. any thoughts....?
