OK, so here's my situation. I have a '98 Bayliner Cierra 2655. I had a new engine dropped in last year, along with 2 new batteries. I recently left my fishfinder on for a week and drained both batteries. I figured I'd just plug into shore power, flip on "battery charger" switch on the cabin panel, and I'd come back to a full battery. Nope. It's been 5 days, and it's dead as doornail. I also don't have some regular stuff working like radio, hot water, and interior lights --even though I'm plugged into shore power (receptacles, microwave, and fridge work). That seems strange, as I would expect shorepower to bypass these things, despite 2 dead batteries.
So... I'm kind of at a loss here. I'm hesitant to go buy a couple new marine batteries, if there's something else going on. for example, I'm worried my charger isn't working properly because, well.. my batteries aren't being charged despite being plugged into shorepower. So far, I've checked all the fuses under the dash (OK). Are there other fuses somewhere else I should be checking? If so, I dont know where they would be. Is it normal to have no radio/interoir lights/hot water when the battery is dead, but plugged into shorepower? This was why I was suspecting a blown fuse somewhere. Lastly, I'm a bit clueless about the operating condition of the battery charger, and not sure if that's the problem, or if it's my batteries (only 1 year old). Any thoughts/tips on how I can test check both of these (charger& batteries).
I have a Statpower TrueCharge 10HW, with a yellow light one that says "Absorption". See picture below I have no idea what this means, and I couldn't find a manual on line. But given that there's a light showing tells me it's working? And shorepower should supply current to this? Also, there is a Guest switch next to it. This just turns on 1,2, or both batteries. It looks like there are some inline fuses below it. I figured I check with smarter folks than myself before I opened up the unit up searching for fuses. Any insight is much appreciated. Thanks!
