Best way to seal and paint marine plywood-gctid751478
    As the topic suggests I am looking for tips on how best to seal a piece of marine plywood I will use to replace a panel in the locker at the base of the ladder leading to the fly bridge on my 1987 3216. The old panel is white in color. Any ideas?
    IMO epoxy resin
    "THE FIX"
    '93 2556
    Misc. projects thread
      Epoxy
      Be sure to put in drain holes and seal the edges.
      I'm just wrapping up redoing all my cockpit seating and I replaced all the marine plywood and sealed it all with the epoxy. Do at least two coats. In the end I did two or three as I went back over areas.
      Jim McNeely
      Twin 5.7s with Bravo2 drives
      Brighton, Michigan USA
      MMSI # 367393410
        First off use "all weather wood"
        It is a brown plywood product that is treated and absolutly will not rot...Ever.
        Then just paint is with a good exterior grade oil based enamel paint. Choose your brand.
        www.transferswitch4less.com
        where are we right now?
          Change out the plywood for Starboard - I'm about to do the same thing...
          ________________
          1989 Bayliner 3270
            It came out great. Used marine ply, two coats of epoxy all sides, the used Rustoleum Top Side to paint it. Smooth as can be. Thanks all.
