i just bought a 1995 2452 express cruiser. had it out twice and found it is taking on water in the cabin area. i looked under the boat and found there is a what looks to me like a bilge drain hole that conects to the toilet with a shutoff,the other is a bilge type hole with some kind of deflector on it that faces foreward so that when you are going foreward seawater is forced into the hole,the hole is just foreward of the engine. i bought boat from a dealer and they know nothing about it. i also put fresh water into the fresh water tank until it came out the spout,only to find out i flooded the cabin, whats up.
holes in bottom of 1995 2452 bayliner-gctid388805
i looked under the boat and found there is a what looks to me like a bilge drain hole that connects to the toilet with a shutoff,[COLOR]"#0000CD" wrote:
That would be your raw water intake for the toilet[/COLOR]
the other is a bilge type hole with some kind of deflector on it that faces forward so that when you are going forward seawater is forced into the hole, the hole is just forward of the engine. [COLOR]"#0000FF" wrote:
Another raw water intake for ????[/COLOR]
i bought boat from a dealer and they know nothing about it. i also put fresh water into the fresh water tank until it came out the spout, only to find out i flooded the cabin, whats up. [COLOR]"#0000FF" wrote:
Check your hose, fittings and clamps to and from your fresh water tank for leaks. You may have a hole in the tank, but check the lines and fittings first.[/COLOR]
