Hello, guys I have a pretty bad gear oil leak on my 94 Bayliner 2252 with alpha one gen 2 outdrive. It has a remote reservoir inside the boat. The leak is evident where the lower unit is bolted to the upper unit. Is it as simple as dropping the lower unit and resealing the joint where it meets up with the upper? I'm afraid the leak may actually be where the upper unit bolts to the transom housing. I had trouble with that gasket when I did my gimble, and ended up having to put RTV on the gasket. Could some other part be leaking and it come out at the joint of the upper/lower units?
Boyce
Boyce
