We had a scare yesterday. Got back to the marina after about 3 hours of running the boat. When they had it up on the forks to put it back in the rack and pulled the garboard drain plug about 1 1/2 gallons of gas came out of the bilge. I climbed up and when I opened the hatch saw the port engine fuel/water filter was leaking around the top of the filter. Pretty good leak too. At the rate it was coming out it must have only been leaking for about 45 minutes---about the time it took us to get back to the marina from Ft. McRee. Took almost a full turn to tighten it back up and stop the leak. Hosed the bilge out for about 20 minutes.
Talked to my mechanic last night he said there are two issues with Mercruiser/Volvo filters. 1. Alcohol can cause the rubber gasket to shrink and make it loosen up and 2. a loose fitting in the filter head. Both were replaced about 60 engine hours ago so it was not as simple as did not tighen them up enough. Going to pull and replace both of them this week. Will let you know what I find out.
I guess my pre-start routine will now include hand testing them to see if they are tight in addition to checking the oil and bilges.
This could have been really bad. Like my 80 year old Norwegian sailing master used to beat into our heads every chance he had, "Give them a chance and the boat and the sea will kill you without remorse."
